Access SAS options from the File > SAS menu:
Select and import data on a SAS server without writing SQL statements. See Build SQL Queries in Query Builder for details.
You can also find shortcuts for SAS options on the SAS page of the JMP Starter, and there is a SAS toolbar. You can save certain settings pertaining to SAS Integration on the SAS Integration page of the Preferences window (File > Preferences). For more information about setting your SAS Integration preferences, see SAS Integration in JMP Preferences.
