SAS Integration preferences customize the default settings for working with SAS servers. For details about using the SAS Integration capabilities, see Import Data from SAS in Import Your Data.
Note: The SAS Environment options appear after you select SAS 9.3 or 9.4 from the SAS Server Version list.
Select the default version for the SAS Server. This can also be changed in the Server Connections window. (See Connect to a SAS Metadata Server in Import Your Data.) This option does not apply when connecting to local SAS on Windows.
Select this option to always connect to a SAS Environment and click Configure to configure the URL of the location.
Select a graph format: ActiveX Image (available only on a SAS server that runs on Windows), Java Image, PNG, JPEG, or GIF.
