Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
• Introduction to Consumer Research
Overview of Customer and Behavioral Research Methods
JMP provides a full suite of tools for analyzing consumer and behavioral research data. You collect information about how customers use products or services, how satisfied they are with your offerings, and what new features they might desire. The resulting insights let you create better products and services, happier customers, and more revenue for your organization. Tools for analyzing these consumer research activities are located in the Consumer Research menu. Use the following platforms to analyze your data:
The Categorical platform enables you to tabulate, plot, and compare categorical responses in your data, including multiple response data. You can use this platform to analyze data from surveys and other categorical response data, such as defect records and study participant demographics. Using the Categorical platform, you can analyze responses from data that are organized in many different ways. For more information, see
Categorical Response Analysis
The Multiple Correspondence Analysis (MCA) platform takes multiple categorical variables and seeks to identify associations between levels of those variables. MCA is frequently used in the social sciences particularly in France and Japan. It can be used in survey analysis to identify question agreement. For more information, see
The Multidimensional Scaling (MDS) platform enables you to create a visual representation of the pattern of proximities (similarities, dissimilarities, or distances) among a set of objects. For more information, see
The Factor Analysis platform enables you to construct factors from a larger set of observed variables. These factors are expressed as linear combinations of a subset of the observed variables. Factor analysis enables you to explore the number of factors that are explained by a set of measured, observed variables, and the strength of the relationship between factors and variables. For more information, see
Factor Analysis
The Choice platform is designed for use in market research experiments, where the ultimate goal is to discover the preference structure of consumers. Then, this information is used to design products or services that have the attributes most desired by consumers. For more information, see
Choice Models
The MaxDiff platform is an alternative to using standard preference scales to determine the relative importance of items being rated. A MaxDiff model forces respondents to report their most and least preferred options, thereby forcing respondents to rank options in terms of preference. For more information, see
MaxDiff
The Uplift platform enables you to maximize the impact of your marketing budget by sending offers only to individuals who are likely to respond favorably, even when you have large data sets and many possible behavioral or demographic predictors. You can use uplift models to make such predictions. This method has been developed to help optimize marketing decisions, define personalized medicine protocols, or, more generally, to identify characteristics of individuals who are likely to respond to some action. For more information, see
Uplift Models
The Item Analysis platform enables you to fit item response theory models. The Item Response Theory (IRT) method is used for the analysis and scoring of measurement instruments such as tests and questionnaires. IRT uses a system of models to relate a trait or ability to an individual’s probability of endorsing or correctly responding to an item. IRT can be used to study standardized tests, cognitive development, and consumer preferences. For more information, see
Item Analysis
Help created on 9/19/2017
