Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
• MaxDiff
MaxDiff
Fit Models for MaxDiff Experiments
Use MaxDiff (maximum difference scaling) as an alternative to standard preference scales to determine the relative importance of items being rated. MaxDiff forces respondents to report their most and least preferred options. This often results in rankings that are more definitive than rankings obtained using standard preference scales.
The MaxDiff platform enables you to do the following:
Use information about subject traits as well as product attributes.
Integrate data from one, two, or three sources.
Obtain subject-level scores for segmenting or clustering your data.
Estimate subject-specific coefficients using a Bayesian approach.
Use bias-corrected maximum likelihood estimators (Firth, 1993).
MaxDiff All Comparisons Report
Contents
MaxDiff Modeling Platform Overview
Examples of the MaxDiff Platform
One Table Format
Multiple Table Format
Launch the MaxDiff Platform
Launch Window for One Table, Stacked
Launch Window for Multiple Tables, Cross-referenced
MaxDiff Model Report
Effect Summary
MaxDiff Results
Parameter Estimates
Bayesian Parameter Estimates
Likelihood Ratio Tests
MaxDiff Platform Options
Comparisons Report
Save Bayes Chain
Help created on 9/19/2017
