Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Profilers
Surface Plot
• Keyboard Shortcuts
Keyboard Shortcuts
The following keyboard shortcuts can be used to manipulate the surface plot.
Surface Plot Keyboard Shortcuts
Key
Function
left, right, up, and down arrows
spin
Home, End
diagonally spin
Enter (Return)
toggles ArcBall appearance
Delete
roll counterclockwise
Control
boost spin speed 10X
Shift
allows continual spinning
Help created on 9/19/2017
