Select one of three control chart types: Indiv and MR (Individual Measurement and Moving Range), XBar and R, or XBar and S. For more information about statistical details, see Statistical Details in the Quality and Process Methods book.
Specify a value that controls the sensitivity of the Shift Graph. Shift Threshold is set to three by default. After outlier removal, the Shift Graph shows a plot of the time occurrence of all process shifts that exceed the number of within-sigma units specified by the Shift Threshold. See Shift Graph.
Specify a value that controls the sensitivity of outlier removal for detection of large recent shifts and for the Shift Graph. Outlier Threshold is set to five by default. If the number of within sigma units from an observation to both of its neighboring observations exceeds the specified Outlier Threshold, that observation is replaced with a value that is one within-sigma unit away from its closest neighboring observation. See Shift Magnitudes and Positions.
Enables you to change the exponentially-weighted moving average (EWMA) weight used in the Shift Graph. See Shift Magnitudes and Positions.
Enables you to import historical control limits and specification limits from a data table. When you select this option and click OK in the launch window, a Limits Specification window appears. Assign columns in your limits table to appropriate roles and click OK. For details. See Limits Table.
Estimates the center line using the median of the observations. Sigma is estimated using scaling factors obtained using Monte Carlo simulation. The table of factors is given in Statistical Details. The calculation depends on the type of chart selected:
