Adds columns for Largest Upshift and Upshift Position to the Summary table. The largest upward shift in the series that exceeds one within-sigma unit is identified. See Shift Magnitudes and Positions.
Adds columns for Largest Downshift and Downshift Position to the Summary table. The largest downward shift in the series that exceeds one within-sigma unit is identified. See Shift Magnitudes and Positions.
Note: The Shift Graph does not show the positions of Largest Upshift and Largest Downshift values that appear in the Summary table if the shifts are less than the specified Shift Threshold number of within-sigma units in magnitude. See Additional Example of Process Screening.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
