The Life Distribution report lets you compare distributions and work with profilers to find the right fit. And when you select a distribution in the Forecast report, the Life Distribution report is updated. See Life Distribution topic for more information about this report. Some of the options described in the Life Distribution chapter are not available in the Life Distribution report in the Reliability Forecast platform.
