Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
MaxDiff Design
MaxDiff Window
• Make Table
Make Table
The Make Table button creates the design table. The design table consists of four columns:
Subject
Initially populated by ones. Replace with appropriate identifiers for respondents.
Tip:
To easily add respondent identifiers, see
Fill Columns with Sequential Data
in the Enter and Edit chapter of the
Using JMP
book. Use Columns >Recode to change the identifiers to names.
Choice Set
A designator for each choice set.
Factor
The levels of the factor that you specified. These are the items in the choice set.
Choice
A column where you can enter results. Use a numeric value to indicate the best choice, the worst choice, and choices in between. The values 1, -1, and 0 are typically used and are required for analysis by the MaxDiff analysis platform (located at Analyze > Consumer Research > MaxDiff).
Help created on 9/19/2017
