A JMP add-in is a file that has the .jmpaddin extension. You can install it in one of two ways:
Select File > Open.
Navigate to the .jmpaddin file and select it.
Click Open.
You can also double-click the .jmpaddin file or drag it onto the JMP Home Window.
Select View > Add-Ins to see the add-ins that you have already installed.
Select View > Add-Ins.
Deselect the Enabled check box.
Select the Enabled check box.
Click Unregister.
