Ternary Plot uses the Mixture column property to shade the portion of the graph that is out of bounds. The only constraints that the Ternary plot recognizes are the mixture sum and the mixture bounds. The Ternary plot does not recognize a general linear constraint like the Mixture Profiler does. For information about setting the Mixture column property in the Column Info window, see Mixture in the Using JMP book.
