Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
Ternary Plots
• Ternary Plot Platform Options
The red triangle menu next to Ternary Plot contains options to modify the plot.
Note:
To view more detailed options, right-click on the plot.
Show Constraints
Shows or hides the constraints on the plot. The default plot shows the constraints.
Contour Fill
Allows filling of contours if a contour formula is specified in the plot. You can select Lines Only, Fill Above, or Fill Below. The default platform shows lines only.
Color Theme
Allows you to select a color theme. The default plot shows the Blue to Gray to Red color theme.
Show Points
Shows or hides the plotted points. The default plot shows the points.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
Help created on 9/19/2017
