Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Process Capability
Process Capability Platform Options
• Normalized Box Plots
The Within Sigma Normalized Box Plots and Overall Sigma Normalized Box Plots options show or hide box plots that have been normalized using the within sigma and overall sigma, respectively. When drawing normalized box plots, JMP standardizes each column by subtracting the mean and dividing by the standard deviation. The box plots are formed for each column using these standardized values.
shows the Within Sigma Normalized Box Plot for a selection of the process variables in the
Semiconductor Capability.jmp
sample data table using
wafer
as a subgroup variable.
The green vertical lines represent the specification limits for each variable normalized by the mean and standard deviation of each variable. The gray dotted vertical lines are drawn at ±0.5, since the data is standardized to a standard deviation of 1.
Help created on 9/19/2017
