Shows or hides individual detail reports for each variable in the analysis. See Individual Detail Reports for more information.
Shows or hides a goal plot for the data. The Goal Plot shows the spec-normalized mean shift on the x-axis and the spec-normalized standard deviation on the y-axis for each variable. See Goal Plot for more information. (Only variables for which you specify normal distributions are shown on the plot.)
Shows or hides a capability box plot for each variable in the analysis. The values for each column are centered by their target value and scaled by twice the minimum difference between the target value and the specification limits. See Capability Box Plots for more information. (Box plots are shown only for variables for which you specify normal distributions.)
Provides two options for plots that show normalized box plots for each process variable. Each column is standardized by subtracting its mean and dividing by an estimate of the column’s standard deviation. The box plot is constructed using quantiles for the standardized values. See Normalized Box Plots for more information. (Normalized box plots are shown only for variables for which you specify normal distributions.)
Shows overall Ppk values for all variables that you entered as Y, Process. See Capability Index Plot.
Provides two options for summary reports of capability indices. See Summary Reports for more information.
Creates a summary table for the points plotted in the Goal Plot. This table includes the variable’s name, its spec-normalized mean shift, and its spec-normalized standard deviation. Each variable has two rows in this table: one for each sigma type (within and overall). See Make Goal Plot Summary Table for more information.
Saves the specification limits to a column property for each variable in the analysis. If no spec limit column property is present, the column property is created. If a spec limit column property is present, the values in the column property are overwritten. See Spec Limits Column Property for more information.
Saves the specification limits to a limits data table in tall format. See Limits Data Table for more information.
Saves the distribution used in calculating capability as a Process Capability Distribution column property. See Process Capability Distribution in the Using JMP book.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
