The Parameter Estimates for Original Predictors report gives estimates and other results for all parameters in the model. These include the coefficients for predictors and additional parameters such as scale, dispersion, or zero inflation parameters. See Distribution.
The p-value for the Wald test.
The lower bound for a 95% confidence interval for the parameter. You can change the α level in the Fit Model window by selecting Set Alpha Level from the red triangle menu.
The upper bound for a 95% confidence interval for the parameter. You can change the α level in the Fit Model window by selecting Set Alpha Level from the red triangle menu.
