The red triangle menu next to Pareto Plot has commands that customize the appearance of the plots. It also has options in the Causes submenu that affect individual bars within a Pareto plot. The following commands affect the appearance of the Pareto plot as a whole:
Per Unit Rates compares defect rates across groups. If a sample size is specified, Defects Per Unit (DPU) and Parts Per Million (PPM) columns are added to the report.
Test Rate Within Groups tests (a likelihood ratio chi-square) whether the Defects Per Unit (DPU) across causes are the same within a group.
Test Rates Across Groups tests (a likelihood ratio chi-square) whether the Defects Per Unit (DPU) for each cause is the same across groups.
Has options that affect one or more individual chart bars. See Causes Options, for a description of these options.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
