The Prediction Variance Profile outline shows a profiler of the relative variance of prediction. Select the Optimization and Desirability > Maximize Desirability option from the red triangle next to Prediction Variance Profile to find the maximum value of the relative prediction variance over the design space. For details, see Maximize Desirability.
The Prediction Variance Profile plots the relative variance of prediction as a function of each factor at fixed values of the other factors. Prediction Variance Profiler shows the Prediction Variance Profile for the Bounce Data.jmp data table, located in the Design Experiment folder.
You can also evaluate a design or compare designs in terms of the maximum relative prediction variance. Select the Optimization and Desirability > Maximize Desirability option from the red triangle next to Prediction Variance Profile. JMP uses a desirability function that maximizes the relative prediction variance. The value of the Variance displayed in the Prediction variance Profile is the worst (least desirable from a design point of view) value of the relative prediction variance.
Prediction Variance Profile Showing Maximum Variance shows the Prediction Variance Profile after Maximize Desirability was selected. The plot is for the Bounce Data.jmp sample data table, located in the Design Experiment folder. The largest value of the relative prediction variance is 1.395833. The plot also shows values of the factors that give this worst-case relative variance. However, keep in mind that many settings can lead to this same relative variance. See Prediction Variance Surface.
Help created on 9/19/2017
