Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Compare Designs
Compare Designs Window: Specify Model and Alias Terms
• Reference Design
Reference Design
The name of the window for the reference design appears in the outline title. The Matching Specification outline lists the specifications that you entered in the launch window.
Help created on 9/19/2017
