Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
• Compare Designs
Compare
Designs
Compare and Evaluate Designs Simultaneously
The Compare Designs platform compares two or three designs simultaneously to explore and evaluate their performance. Diagnostics show how the designs perform relative to each other and how they perform in an absolute sense. To compare designs relative to your specific needs, you can change the terms in the assumed model and in the alias terms list.
Comparing Three Designs with Different Run Sizes
Contents
Overview of Comparing Designs
Examples of Comparing Designs
Designs of Same Run Size
Designs of Different Run Sizes
Split Plot Designs with Different Numbers of Whole Plots
Compare Designs Launch Window
Compare Designs Window: Specify Model and Alias Terms
Reference Design
Factors
Model
Alias Terms
Compare Designs Window: Design Evaluation
Power Analysis
Prediction Variance Profile
Fraction of Design Space Plot
Relative Estimation Efficiency
Alias Matrix Summary
Absolute Correlations
Design Diagnostics
Compare Designs Options
Help created on 9/19/2017
