(Available only when SVD is selected from the red triangle menu next to Association Analysis.) The Rotated SVD option performs a varimax rotation on the singular value decomposition (SVD) of the transaction item matrix. See Transaction Item Matrix. You must specify a number of rotated singular vectors, which corresponds to the number of topics that you want to retain from the transaction item matrix. After you specify a number of topics, the Topic Terms and Topic Scores Plots reports appear. Topic analysis is equivalent to a rotated principal components analysis (rotated PCA).
Topics are groups of transactions that are grouped based on a primary item indicator, as well as secondary item indicators. For each topic, every item has a weight that influences a transaction’s membership in the topic. The cumulative sum of the item weights for all of the items that are present in a transaction is called the topic score. Topic scores reflect the strength of a transaction’s membership for a topic.
(Available only when Rotated SVD is selected from the red triangle menu next to Association Analysis.) The Topic Scores Plots report is a visual representation of the matrix in the Document Topic Scores report. Each panel in the plot corresponds to one of the topics, or one of the rows of the Document Topic Scores matrix. Within each panel, each point corresponds to one of the transactions in the data table, or one of the columns of the transaction item matrix. See Additional Example: SVD Analysis.
