Shows or hides a list of item sets whose support exceeds the Minimum Support value specified in the launch window. See Frequent Item Sets for more information.
Shows or hides a table of association rules that meet the Minimum Support, Minimum Confidence, Minimum Lift, Maximum Antecedents, and Maximum Rule Size requirements specified in the launch window. See Rules for more information.
Shows or hides scatterplots of the first two singular vectors for transactions and for items, calculated by singular value decomposition on the incidence matrix for the items. The report also contains a table of singular values sorted in descending order. The Percent and Cum Percent columns show the additional and cumulative variability in the data explained by the corresponding singular value. The bar chart shows the Percent variation explained by each singular value. For more information, see SVD.
(Available only if SVD is selected.) Shows or hides the Topic Items and Topic Scores reports. This option performs a varimax rotated singular value decomposition of the transaction item matrix to produce groups of similar transactions called topics. See Rotated SVD.
Creates a data table that contains a number of singular vectors that you specify for each transaction. These are the left singular values in the transaction item matrix. See Singular Value Decomposition.
Creates a data table that contains a number of singular vectors that you specify for each item. These are the right singular values in the transaction item matrix. See Singular Value Decomposition.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
