Select the project name and click the Save Selected Project button on the Projects window toolbar.
In another open JMP window (such as the JMP Home Window), select File > Save Projects.
When you save a project, JMP creates a compressed file with the .jmpprj extension and saves a copy of each item in the project. If you make subsequent changes, the archived copy is modified rather than the original source. Other JMP users on Windows and Mac can then open the project on their computers, and the links remain intact.
The project has a link to the C:\MyDataTables folder.
In these instances, turn off archiving by right-clicking the project in the Projects window and deselecting Archive all files and folders when project is saved.
When you save a project, JMP notifies you when files in the project archive are not found. See Fix Broken Links for details about fixing the links.
