Save and Share Reports
To save a report, select File > Save As.
On Macintosh, the report is saved as a JMP report (.jrp). Note the following:
If you want to save the report as a text, image, HTML, PowerPoint, or RTF file, select File > Export. Supported image files include .eps, .png, .svg, and .tiff.
Microsoft Word (.doc)
Enhanced Metafile (.emf)
Line drawing (or vector image) that can show a bitmap preview of the image.
Hypertext Markup Language (.htm, .html)
Interactive HTML (.htm, .html)
Joint Photographics Expert Group (.jpg, .jpeg)
JMP Journal (.jrn)
Analysis report duplicated in a separate window titled Journal. You can edit it or append other reports to it. See JMP Journals.
Note that on Macintosh, select Edit > Journal, and then File > Save. On Windows, choose File > Save, and then choose the journal format.
JMP Report (.jrp)
Rich Text Format (.rtf)
Text Format (.txt)
