Export Column Names to Text File To save column headings in the first line of text, and to save labels or header information with the data, select Export Table Headers.
End of Field Select the radio button next to the character that marks the end of a field (or cell). Select Other and enter a character if the appropriate character is not listed.
End of Line Select the radio button next to the character that marks the end of a line (or row). Select Other and enter a character if the appropriate character is not listed.
Notes:
Select File > Save As.
Select Text Export File from the Save as type list.
Click the Options button and specify end-of-line and end-of-field characters, and choose whether to export column headings as text.
Click Save.
7.
Click Yes.
Select File > Export.
Select Text and click Next.
Enter a name for the file in the Save As box and change the extension to .txt.
6.
Click Export.
Help created on 9/19/2017
