Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Cause-and-Effect Diagrams
Save the Diagram
• Save the Diagram as a Script
From the red triangle menu, select
Save Script > To Script Window
Save the new script.
Note the following about this approach:
If you have other processes that need to update the data table, this can be a good approach to choose.
If you created the diagram from a data table, a simple script appears that relaunches against the data table with no customization.
If you created the diagram without using a data table (or from a journal), a more complex script appears that contains all the commands needed to add and customize each area of the diagram.
Help created on 9/19/2017
