Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
• Cause-and-Effect Diagrams
Identify Root Causes
Use the Diagram platform to construct cause-and-effect diagrams, also known as
Ishikawa charts
or
fishbone charts
. Use these diagrams to:
Organize the causes of an effect (sources of a problem)
Brainstorm
Identify variables in preparation for further experimentation
Example of a Cause-and-Effect Diagram
Contents
Cause-and-Effect Diagram Overview
Prepare the Data
Launch the Diagram Platform
The Cause-and-Effect Diagram
Right-Click Menus
Save the Diagram
Save the Diagram as a Data Table
Save the Diagram as a Journal
Save the Diagram as a Script
Help created on 9/19/2017
