Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Enter and Edit Data
• Select Columns
Select Columns
There are several ways to select columns:
Select columns in the data table itself. See
Select Columns in a Data Table
In a data table that has many columns, select columns by attributes, properties, and statistics in the Columns Viewer. See
Select Columns in the Columns Viewer
Help created on 9/19/2017
