Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
JMP Reports
Navigate Reports
• Show and Hide Parts of a Report
JMP reports are organized in a hierarchical outline. Each level of the outline has a triangle-shaped disclosure button
. Click the disclosure button to open and close that section of the report.
You can also change which columns appear in a report. Right-click the report and select the column from the Columns list. To select more than one column at once, press Alt before right-clicking.
Help created on 9/19/2017
