Saves the results of the simulation to a data table. If a response has specification limits, the table includes a Y In Spec column that indicates if the simulated response is within the specification limits. The table also includes an Objective column, labeled Obj. If you have requested Desirability functions prior to simulation, this column is the evaluation of the desirability function that you have created for your responses. If no desirability functions have been requested, the column contains all missing values.
