Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Distributions
Statistical Details for the Distribution Platform
• Standard Deviation Test
Here is the formula for calculating the Test Statistic:
The Test Statistic is distributed as a Chi-square variable with
n
- 1 degrees of freedom when the population is normal.
The Min PValue is the
p
-value of the two-tailed test, and is calculated as follows:
2*min(p1,p2)
where p1 is the lower one-tail
p
-value and p2 is the upper one-tail
p
-value.
Help created on 9/19/2017
