There are N observations:
The differences between observations and the hypothesized value m are calculated as follows:
There are N pairs of observations from two populations:
When there are tied absolute differences, they are assigned the average, or midrank, of the ranks of the observations.
R+ is the sum of the positive signed ranks
For
, exact p-values are calculated.
For N > 20, a Student’s t approximation to the statistic defined below is used. Note that a correction for ties is applied. See Iman (1974) and Lehmann (1998).
The last summation in the expression for Var(W) is a correction for ties. The notation di for i > 0 represents the number of values in the ith group of non-zero signed ranks. (If there are no ties for a given signed rank, then di = 1 and the summand is 0.)
The statistic t given by the following has an approximate t distribution with N - 1 degrees of freedom:
