Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Cluster Variables
The Cluster Variables Report
• Standardized Components
The Standardized Components report gives the coefficients that define the cluster components. These coefficients are the eigenvectors of the first principal component within each cluster.
Help created on 9/19/2017
