Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Cluster Variables
• The Cluster Variables Report
By default, the Cluster Variables report displays the following:
Color Map on Correlations
Cluster Summary
Cluster Members
Standardized Components
Tip:
In any of the Cluster Variables reports, select rows in order to select the corresponding columns in the data table. Hold down Ctrl and click the row to deselect the column in the data table.
Help created on 9/19/2017
