As each step is taken, the Step History report records the effect of adding a term to the model. For example, the Step History report for the Fitness.jmp example shows the order in which the terms entered the model and shows the statistics for each model. See Example Using Stepwise Regression.
Step History Report
Help created on 9/19/2017
