Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Stepwise Regression Models
• The Stepwise Report
The Stepwise Report
The Stepwise report window contains platform options, a regression control panel, current estimates, and step history.
Platform options
The red triangle menu next to Stepwise Fit contains options that affect all of the variables. See
Stepwise Platform Options
Stepwise Regression Control
Limits regressor effect probabilities, determines the method of selecting effects, starts or stops the selection process, and creates a model. See
Stepwise Regression Control Panel
Current Estimates
Enters, removes, and locks in model effects. See
Current Estimates Report
Step History
Records the effect of adding a term to the model. See
Step History Report
Help created on 9/19/2017
