Performs K-Fold cross validation in the selection process. When selected, this option enables the Max K-Fold RSquare stopping rule (Stepwise Regression Control Panel).
Available only for continuous responses. For more information about validation, see Using Validation.
Fits all possible models up to specified limits and shows the best models for each number of terms. Enter values for the maximum number of terms to fit in any one model. Also enter values for the maximum number of best model results to show for each number of terms in the model. Categorical variables are represented using indicator variables. See Models with Nominal and Ordinal Effects. You can restrict the models that appear to those that satisfy strong effect heredity. See The All Possible Models Option.
Enables you to average the fits for a number of models, instead of picking a single best model. See The Model Averaging Option.
Creates a plot of AICc and BIC versus the number of parameters. The Criterion History plot contains two shaded zones. Define the minimum AICc value as Vbest. The green zone is defined by the range [Vbest, Vbest+4]. The yellow zone is defined by the range (Vbest+4, Vbest+10].
