Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Scripting Platforms
Scripting-Only Messages and Arguments by Platform
• Surface Plot
Surface Plot
The following messages for a Surface Plot object can also be controlled in JMP, but might not have corresponding options in the red triangle menu:
surface_plot_object << Mode( "Isosurface" | "Sheet" )
// Isosurface uses three independent variables as the X, Y, and X axis and simultaneously plots the surfaces for the dependent variables on the plot. Sheet has one Z response that is dependent upon two independent X, Y variables.
surface_plot_object << Set Z Axis( col, Current Value(
n
// set the Z axis by referencing the column
surface_plot_object << Set Variable Axis( col, Current Value(
n
// set the independent variable axes by referencing each individual column
surface_plot_object << Response( ... )
// identify up to four response columns for plotting overlaid points
surface_plot_object << Formula( ... )
// assign formulas to columns in the sheets in a specified order
Help created on 9/19/2017
