Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Scripting Platforms
Scripting-Only Messages and Arguments by Platform
• Text Explorer
Text Explorer
The following JSL messages for a Text Explorer object are available only in JSL:
text_explorer_object << Minimum Frequency for Phrase( n )
// specifies minimum number of occurrences a phrase must have to be included in the phrase list
text_explorer_object << Save Indicators for Most Frequent Words( ... )
// alias for Save Document Term Matrix()
text_explorer_object << Save Word Table( ... )
// alias for Save Term Table()
text_explorer_object << Score Words by Column( ... )
// alias for Save Terms by Column()
text_explorer_object << Set Regex( ... )
// replaces default regular expressions used in Regex tokenizing
text_explorer_object << Save Regex Column( string )
// creates a new column with tokenized results
text_explorer_object << Add Delimiters( string )
// adds user-defined delimiter characters, specified in a single string
text_explorer_object << Set Delimiters( string )
// replaces default delimiter characters, specified in a single string
text_explorer_object << Add Stop Words( list )
text_explorer_object << Add Phrases( list )
text_explorer_object << Add Stem Exceptions( list )
text_explorer_object << Add Stem Overrides( list )
// adds a list of words that are always allowed to be stemmed
text_explorer_object << Add Stop Word Exceptions( list )
// adds a list of words to remove from the list of stop words
text_explorer_object << Add Phrase Exceptions( list )
// adds a list of phrases to remove from the list of specified phrases
text_explorer_object << Add Recodes( list )
// adds a list of pairs of words to recode
text_explorer_object << Add Recode Exceptions( list )
// adds a list of recoded text strings to remove
text_explorer_object << Terms Alphabetical( Boolean )
text_explorer_object << Phrases Alphabetical( Boolean )
text_explorer_object << Cloud Width( pixels )
// sets the width of the word cloud in pixels
Help created on 9/19/2017
