After main effects, all second-order interactions are brought in, followed by third-order interactions, and so on. The second-order interactions cross with all earlier terms before bringing in a new term. For example, with size-ordered main effects A, B, C, and D, B*C enters before A*D. If a factor has more than two levels, square and higher-order polynomial terms are also considered.
The process continues until n effects are obtained, where n is the number of rows in the data table, thus fully saturating the model. If complete saturation is not possible with the factors, JMP generates random orthogonalized effects to absorb the rest of the variation. They are labeled Null n where n is a number. For example, this situation occurs if there are exact replicate rows in the design.
