JMP uses the modeling type to determine a column’s role. Continuous columns are assumed to be analysis columns. See Analysis Columns. Ordinal or nominal columns are assumed to be grouping columns. See Grouping Columns.
You can always change the default action by right-clicking on a column and selecting Combine Tables or Separate Tables. For more details, see Right-Click Menu for Columns.
