Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Tabulate
Tabulate Platform Options
• Right-Click Menu for Columns
Right-click on a column in Tabulate to see the following options:
Delete
Deletes the selected column.
Use as Grouping column
Changes the analysis column to a grouping column.
Use as Analysis column
Changes the grouping column to an analysis column.
Change Item Label
(Appears only for separate or nested columns) Type a new label.
Combine Tables (Columns by Categories)
(Appears only for separate or nested columns) Combines separate or nested columns. See
Example of Combining Columns into a Single Table
Separate Tables
(Appears only for combined tables) Creates a separate table for each column.
Nest Grouping Columns
Nests grouping columns vertically or horizontally.
Help created on 9/19/2017
