For Continuous Monitoring, the table contains a row for each unit to be tested and the design settings for that unit. Record each unit’s failure time in the Failure Time column or whether the observation was right censored in the Censored column.
For Monitoring at Intervals, the table contains a row for each design setting and time interval combination. The time intervals are defined by the Start Time and End Time columns, which are based on the Inspection Times entered in the Design Choices outline. For each setting and time interval, record the number failing in the Number Failing column.
