Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
Graph Builder
• Work with Axes
Work with Axes
When working with axes, you can do the following:
Merge Variables on a Common Axis
Create Separate Axes in the X and Y Zones
Create a Second Y Axis
Create Nested Axes for Character Variables
Order the Levels of a Categorical Variable
Help created on 9/19/2017
