JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
The Column Info Window
About the Column Info Window
• About Modeling Types
A column in a JMP data table can contain different types of information. However, all information in a single column must have the same data and modeling types.
When you import data, JMP guesses which data and modeling types to use. Therefore, you should verify that JMP has guessed correctly.
When you manually insert data into JMP, you should assign a data type and a modeling type at that time.
Figure 4.3
illustrates the icons that identify the different modeling types.
Figure 4.3
Modeling Type Icons in the Columns Panel
Click on an icon to change the modeling type to
Continuous
Nominal
Ordinal
, or
None
For details, see
Modeling Type
Tip:
You can select Continuous only if your data type is numeric. If the Continuous option is dimmed on the menu and you want to make the column continuous, you must first change the column’s data type in the Column Info window.
Help created on 10/11/2018
