JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP • The Column Info Window
Set Column Attributes and Properties
Use the Column Info window to set specific properties on a column in a data table. Here are some examples of the actions that you can perform on a column:
Change data and modeling types
Change numeric formats
Add formulas
Specify restrictions on values or missing values
Order categorical values or row data
Save specification, control, or response limits
Enter a known value for sigma
You can also standardize attributes and properties across multiple columns, assign a preselected analysis role to columns, and compress columns in a data table.
Figure 4.1
Contents
About the Column Info Window
About Modeling Types
The Short-Integer Format
Numeric Formats
Row State Columns
Initialize Data
Column Properties
Basic Column Properties
Properties That Validate Column Values
Properties That Attach Information to Column Values
Properties That Control the Display of Columns
Properties Used in Modeling and DOE
Properties Associated with Control Charts and Capability
Properties That Control How Columns Are Used in Platforms
SAS Properties
Virtual Join Properties
Additional Properties
Properties Assigned and Controlled by JMP
Standardize Attributes and Properties Across Columns
Recode Values
Standardize Properties
Delete Properties
Example of Standardizing a Formula
Assign a Preselected Analysis Role
Help created on 10/11/2018
