JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Import Your Data
Import Data Using the Excel Add-In
• About the JMP Add-In for Excel
The JMP add-in commands are in two groups:
Transfer to JMP
Preferences
Set preferences for transferring data from Excel to JMP.
Data Table
Transfer the selected data in your Excel file to a JMP data table.
Graph Builder
Transfer the selected data in your Excel file to a JMP data table and launch the Graph Builder platform.
Distribution
Transfer the selected data in your Excel file to a JMP data table and launch the Distribution platform.
Fit Y By X
Transfer the selected data in your Excel file to a JMP data table and launch the Fit Y by X platform.
Fit Model
Transfer the selected data in your Excel file to a JMP data table and launch the Fit Model platform.
Time Series
Transfer the selected data in your Excel file to a JMP data table and launch the Time Series platform.
Control Chart
Transfer the selected data in your Excel file to a JMP data table and launch the Control Chart platform.
Profile in JMP
Create/Edit Model
Set up preferences for using the JMP profiler with Excel data.
Run Model
Run the JMP profiler.
Help created on 10/11/2018
