JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Consumer Research •
Categorical Response Analysis
• Categorical Platform Options
The Categorical red triangle menu contains options that enable you to customize the report according to your needs. The options that are available in a particular report are determined by the response roles, use of grouping categories, and options selected in the launch window.
Report Options
Statistical Testing Options
Additional Categorical Platform Options
Responses Table Options
Help created on 10/11/2018
