Statistical Testing Options
(Available only for multiple response data with one ore more grouping categories.) See Example of the Multiple Response Test. Contains the following tests for independence of responses across each grouping category:
Shows or hides p-values for each cell in the table for a chi-square test of independence. A small p-value indicates a cell with an observed value that is larger or smaller than expected under the assumption that the rows are independent of the columns. The p-values are colored and shaded according to whether the count is larger or smaller than expected. See Example of the Cell Chisq Test.
Help created on 10/11/2018
