The most common control charts are available in the Control Chart Builder and in the Control Chart platform. Use the Control Chart Builder as your first choice to easily and quickly generate charts. JMP automatically chooses the appropriate chart type based on the data. Table 2.3 through Table 2.7 summarize the different control chart types.
XBar (limits computed on range)
XBar (limits computed on standard deviation)
