JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Quality and Process Methods • Control Chart Builder
Create Control Charts Interactively
A control chart is a graphical and analytic tool for monitoring process variation. Use Control Chart Builder to create control charts of your process data. Select the variables that you want to chart and drag them into zones. JMP automatically chooses the appropriate chart type based on the data. The instant feedback encourages further exploration of the data. You can change your mind and quickly create another type of chart, or change the current settings on the existing chart.
Figure 2.1
Control Chart Builder Example
Contents
Overview of the Control Chart Builder
Example of the Control Chart Builder
Control Chart Types
Shewhart Control Charts for Variables
Shewhart Control Charts for Attributes
Rare Event Control Charts
Control Chart Types
Launch the Control Chart Builder
The Control Chart Builder Window
Control Chart Builder Options
Red Triangle Menu Options
Options Panel and Right-Click Chart Options
Right-Click Axis Options
Work with Control Limits
Example of Control Limits
Excluded and Hidden Samples
Additional Examples of the Control Chart Builder
XBar and R Chart Phase Example
p-chart Example
np-chart Example
c-chart Example
u-chart Example
g-chart Example
t-chart Example
3-Way Chart Example
Statistical Details for the Control Chart Builder Platform
Control Limits for XBar and R-charts
Control Limits for XBar and S-charts
Control Limits for Individual Measurement and Moving Range Charts
Control Limits for p- and np-charts
Control Limits for u-charts and c-charts
Levey-Jennings Charts
Control Limits for g-charts
Control Limits for t-charts
Control Limits for 3-way charts
Help created on 10/11/2018
